nat. gas steam boiler with tankless?
Does anyone know of a natural gas steam boiler that also has a tankless coil built in for domestic hot water. have a oil fired steam boiler with a tankless coil that needs to be replaced but cust wants to convert to gas. it's in a tight space. my heating supplier said they don't carry any. only oil fired with tankless. Is there some reason why they don't do tankless coils with nat gas?
  • Peerless used to make
    a steam / hot water boiler with a coil port . I believe it's now their " 63 " series . I'm not sure if it's still an option with that brand .
    We used that boiler with a coil once in a tight spot . Worked pretty well for hot water - one bathroom home though .
  • American plumber_3
    American plumber_3 Member Posts: 3
    I checked out the peerless 63
    It doesn't show an option for a tankless coil. I did find that slant fin makes one called the galaxy that is nat gas steam with a tankless. I wonder why burnham or weil mclain don't make one
  • Phil_6
    Phil_6 Member Posts: 210
    weil mclain
    makes the EG series. Water or steam with optional tankless
  • kevin coppinger_12
    kevin coppinger_12 Member Posts: 27
    conversion burner....
    w/ a MPO or a SMITH 8 series...
  • BRIANJ
    BRIANJ Member Posts: 118
    Peerless hot water
    I believe Peerless still makes the PARTNER hot water storage tank for the 63 series. You may want to check it out.
  • Mitch_5
    Mitch_5 Member Posts: 102
    Weil Mclain
    Does but it is typically special order. You can also install an oil boiler with a conversion burner.
    Why would you want a tank-less?
  • American Plumber_4
    American Plumber_4 Member Posts: 1
    > nat gas?
