Weather pecularities
Mike T., Swampeast MO
Member Posts: 6,928
Thunderstorms and drenching downpours nearly every day for the past week and expected through this week as well. We were a bit dry this year, but not any more. High temps in the 90s and dewpoints well into the 70s. In other words a typical early summer in Swampeast MO...
It's too bad that the Lake Tahoe region isn't getting the rain that central Texas is getting -- there would be much less suffering.
It's been in 90s in southeast Michigan but I hear the rumble of thunder approaching -- and it ain't the scheduled fireworks!
How's your weather?0 -
HHHHHHHOT!
Don't like the weather, wait a minute. It's been pretty brutal in CT for the last couple of days. It's around 90 here with a heat index of 95+. I know that doesn't sound to bad to some of you, but our blood hasn't had a chance to thin yet.
I expect this weather to last until mid January, then get cold for 3 weeks, then get tons of rain in April, beautiful May, in June the top will suddenly fly off the thermometer with scattered days no warmer than 55. I can't figure it out.0 -
93 F. in Boston
and 51% RH (75 degree wet bulb).
No calls yet from our design jobs."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
- 167 Indoor-Air Quality
