Victory upright freezer
ddlong1286@yahoo.com
Member Posts: 139
Hi all,
I am having a problem with a Victroy VF-1 single door freezer. The drain freezes up. Anyone experiance this problem before?
Thanks
Don in MO
Thanks
Don in MO
V is for Victory!
Hi Don !Possibly debris in drain pan blocking the drain hole, or a plugged drain line or a plugged drain trap(if there is one) or a drain line heater or drain pan heater not physicaly close enough to drain hole ! Does this help?0 -
yep
Many of them need to add a heater inside the drain line. Forgot if we got them right from victory or were using bev air ones.0 -
Try hanging
a copper wire around the defrost hanger and let about 3" of into the defrost drain.0 -
SAM
What a cool idea !0 -
Victory no help
Yes I will be getting a drain tube heater or the copper wire. Talked to Victory today and they wanted to know how cold it was. I told them 0, since it is a freezer and had already been told that it would freeze the drain line if it was below 0. Now how do you explain to a customer that your freezer is too cold?!
Anyway the suggestion was insulate the drain line or get a heater for it, but not from us because it doesn't need one.
Thanks for the replies and will find out in about 4 months or so how it works out.
Don in Mo0 -
Don
Happy T-Bird day to you and yours! Why the waiting time to find out?0 -
heat it
Get the heater.. what happens is a very very very small amount of water is left in the bottom of the drain tube at the end of a defrost and freezes between defrost cycles. The frequency depends on if the plastic drain line has been even looked at it seems. After seeing 3 of them started looking real close at ones people were not complaining about sure enough the drains were partially frozen some more than others.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 47 Industry Classes
