Grundfos Alpha Pro
Aidan (UK)
Member Posts: 290
> I don't believe they manufacture anything but <BR>
> 240V 50cycle. Also they have not been listed by <BR>
> UL if that matters.
True.
E-Bay.
> UL if that matters.
True.
E-Bay.
Does anyone have an idea where I could get a Grundfos Alpha Pro circulator in the US (or at least proper voltage/Hz)?0 -
Doubtful
I don't believe they manufacture anything but 240V 50cycle. Also they have not been listed by UL if that matters. I've heard of contractors buying them via the www from a UK site. Maybe do a "google" search for them.
hot rod
Yes I saw them at UK websites. What I am not sure of is if the units will work on 120/60. They probably don't apply line voltage directly to the motor but I don't know how adaptable the power converter is.0 -
No, no, no!
if you're into adapting a EU unit to work in the US, my understanding is that the frequency is not that important, but the incoming voltage is. Only use these on 230/240VAC circuits!
Hot rod has some experience running a sample on US voltages/frequency. It seems to work and once they work over the internal power supply, there is no reason that they cannot produce a 110/115VAC unit also.0 -
I was hoping they would use a universal power supply like you find in things like PCs now days. Or at least a selectable supply voltage. Then they would have only one unit to stock.
UK pumps
That's also my understanding, but I'm not certain. It might cost you a pump to confirm it. The power supply incorporates the speed control and is fixed to the side of the pump housing. There is a 230 V 50Hz power cord in; unauthorised amendments would require electronics expertise.
http://net.grundfos.com/Appl/WebCAPS/LiteratureDetail?documentid=2031&litlanguage=ENU&typecode=ALPFAM&appcode=HEATING&pdfid=5314&language=ENU
On the plumbing side you'd also need the 1 1/2" BSP union screw-on pump connectors and some 22mm to 3/4" adaptors.
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=20850&ts=235040 -
This Grundfos
solar module has been running in my shop on 240V 60 cycle without any noticable problems. Grundfos assures me that 60 cycle does not hurt those 50 cycle motors. Same for the electronics on the Alpha.
hot rod
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
