stethoscope
Firedragon_4
Firedragon_4 Member Posts: 1,434
they do work and are also great for teaching a customer how powerburners make chimney roar. As Dan H. says, 'ya gotta get out of the basement'.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4067&item=6146342367&rd=1&ssPageName=WDVW
  • Roger_2
    Roger_2 Member Posts: 1
    steamtrap stethoscope
    looking for a steamtrap stethoscope
    which is best?doe they work? where can you get one?
  • Dean_7
    Dean_7 Member Posts: 192
    stethoscopes
    Stethoscopes come in several varities and in different price ranges the main difference in price is the quality of the stethoscope. The higher the quality of the stethoscope the more you will be able to hear and more importantly you will be able to DIFFERENTIATE what you hear. I'm an RN and I use a electronic stethoscope because I have to differentiate between subtle heart sounds and lung sounds an it allows me to do so. It's also personal preference. I would suggest doing a google search for stethoscopes. Or you could go to www.allheart.com and pick a midrange litmann stethoscope. They are excellent stethscopes and will allow you to differentiate what you hear.
  • Carl PE
    Carl PE Member Posts: 203
    In a pinch
    You can use a 2' section of broom handle, or any scrap of wood laying around. You'd be surprised at how much you can hear through it.
  • JimGPE_3
    JimGPE_3 Member Posts: 240
    Or
    A long screw driver. Old auto mechanics trick.
