thermostats
JackFre
Member Posts: 225
You could put in a 7 day programmable set-back thermostat and program the days inv=dividually for your comfort/ime settings.
I like to know if ther is a control that I can use to raise the thermostat in my house before I arrive. I have look into Honywell, but the instalation requires to many diferent modules, and the wiring is complicated. The reason I need this is because I have a weekend home, when I arrive there on Friday nights the house is cold. If I could raise the temp before we arrive my wife would not get sick so often, we are old and not as perky as we used to be, please you have helped me in the past, I hope this is not a big problem.0 -
Thermostat
Check Radio Shack. They should have a device that you can attach to the phone in your vacation home. Dial in before to the house on your way there and it will bring the thermostat out of setback. You will need to get a thermostat cable of handling this. There should be several choices out there for you to use.
This solution is a little better because you may decide to go on a day that you don't have the thermostat programmed for occupied temperatures.
good luck
bb
I suggest you look at the Honeywell telephone access module. Go to customer.honeywell.com. Once you're there, scroll down to the very bottom right corner. In the blank box type in W8735. On the list of pdf's that comes up, click on the second one.0 -
www.Sensaphone.com
Sensaphone FGD-1104-CS can be purchased at Graybar or elsewhere for about $300. It speaks in human voice telling you of current temp, it can call you if temp goes too low or if power fails, you can add additional temp sensors. Very easy to use, we've installed them for 3 clients already and they love 'em!0 -
