Steam repair help needed...
gerry_6
Member Posts: 33
hey Tim, go to Grittons you been there ? BTW I'm local hope to meet you someday.
In one pic, you will see the LWCO. The Y on top that unions the LWCO to the sight glass is leaking onto the LWCO. I need the bushing to seal that. Second, the sight glass leaks. Anyone have a source for sight glass bushings? The third thing is the drip from the main valve at the shaft. Is there a replacement packing for this? I found the unit running at 12# and I reduced it to 4# and it was running great. It used to heat 2 indirects, but now only heats one tank. The steam never leaves the mech room and it never shut off....could the steam be set back to 1#?
Thanks, TimJust a guy running some pipes.0 -
That
union gasket is pretty run of the mill MM stuff, usually I just tighten abit, but may need to disassemble & clean,, change nipple too.
Valve, just remove the 2 stuffing-box nuts, pry back the retainer, add some twisted graphite packing & reverse you should be fine.
Dave0 -
Is the LWCO nipple assy available seperate from MM? I did try tightening the leaking joint & the sight glass but no luck....I will have to replace sight glass washer / bushing and the LWCO nipple / gasket..
Couldn`t find
on MM site Tim, so I resorted to my books.
Packing washer is MM# 316400,,, nipple is(special of course), MM# 316500.
Sight glass gaskets I just get from Sexauer.
Dave0 -
another boiler
Another boiler header pipings is installed wrong0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
