Hardwood Adhesive
Alan(OnVacationInOregon)Forbes
Member Posts: 232
Thanks, guys. This helps a lot.
Alan
Alan
Hardwood Adhesive
Has anyone ever used SikaBond-T55 to glue hardwood flooring down to radiant panels such as QuikTrak? It contains Xylene - a solvent and it will be in contact with the PEX tubing.
I have used SikaFlex
in wooden boat building and repair. Great on outdoor projects. Same company, perhaps a different product (marine adhesive).
Did not know it had or might have xylene; good to know. One whiff and.. there goes third grade!0 -
Sika
The Sikaflex I used said not to let it get in contact with your skin. Of course I was covered in it at that point. It's definitely some sticky stuff.
I worked with an architect once who glued C-Fin to his concrete slab using something called Olde Boards glue. It definitely wasn't my idea. Must be still holding.
I think a call to Sika might be necessary to find the answer to this question.0 -
sika
It does contain xyline check out the msds
http://www.sikaconstruction.com/msds-cpd-SikaBondT55-us.PDF
They do state in the product sheet:
"Do not use on PE, PP, TEFLON, and certain plasticized synthetic materials.(Carry out pre-trials)"
http://www.sikaconstruction.com/tds-cpd-SikaBondT55-us.pdf0
- 120 Geothermal
