Duct Design Software - Darin Cook
Darin Cook_5
Darin Cook_5 Member Posts: 298
Can anyone guide me to a good duct sizing/heat gain software? I am looking for something better than just a air duct calculator. Thanks for any help!!
Darin
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    Elite Software
    has a program for residential and light commercial size projects called, amazingly enough, "Duct Size" (How DO they do it??).
    What kind of duct calculator are you using? Charts or a circular sliderule?
    For all of my work and for over 30 years now, I have never used a duct program, just a Trane "Duct-u-lator" or the Loren Cook company equivalent. And I am fast. :)
    Do you have one? I can spot you one if you send me your mailing address. Give me 30 minutes with you and one of those tools and I will have you sizing more ducks than the Northeast Flyway can handle. Trust me.
  • Darin Cook_5
    Sir Brad
    > it??).
    > For
    > Do you have one?
    Darin
  • Darin Cook_5
    Sir Brad
    Thanks for the response. I have a Lima Air Duct Calculator. I am (ahem) a piping guy and while I have assembled plenty of tin (plenty of hand scars to prove it!!), I have not done much in the way of sizing systems.
    A ductulator lesson is definetly in order!
    Great time seeing you in NYC. You are a real gentlemen! Anthony and myself look forward to seeing you soon.
    Darin
  • Brad White_9
    Absolutely, Darin!
    It is the least I can do for you and your service. Fire off your snail-mail address to me and I will get a nice duct calculator on it's way to you soon. We can do a lesson over the phone although face to face is always far better!
    Yes, Friday (into Saturday) was a night to remember. Way too short. Looking forward to seeing you again and to meeting Anthony.
    And don't call me sir! I work for a livin'.... :)
  • hvacfreak
    hvacfreak Member Posts: 439
    Lima calculator
    I like the Lima calculator for the return grille sizes on the back. The Lennox ( and more recently , Home Depot ) calculator has the eqivilant length of fittings on the back. Remember , residential supply duct is .10 static within 100 ft to the longest outlet ( linear plus eqiv. length ). Return duct should be based on 600 fpm ( velocity only as compared to equiv. length with in 100 ft ). Low velocity return ducts make for great residential ac and heat pump systems ( and commercial for that matter ). - FREEEEEEEEEAK !!!
