Duct Design Software - Darin Cook
Darin Cook_5
Member Posts: 298
Can anyone guide me to a good duct sizing/heat gain software? I am looking for something better than just a air duct calculator. Thanks for any help!!
Darin
Darin
Elite Software
has a program for residential and light commercial size projects called, amazingly enough, "Duct Size" (How DO they do it??).
What kind of duct calculator are you using? Charts or a circular sliderule?
For all of my work and for over 30 years now, I have never used a duct program, just a Trane "Duct-u-lator" or the Loren Cook company equivalent. And I am fast.
Do you have one? I can spot you one if you send me your mailing address. Give me 30 minutes with you and one of those tools and I will have you sizing more ducks than the Northeast Flyway can handle. Trust me.0 -
Sir Brad
> it??).
> For
> Do you have one?
Darin0 -
Sir Brad
Thanks for the response. I have a Lima Air Duct Calculator. I am (ahem) a piping guy and while I have assembled plenty of tin (plenty of hand scars to prove it!!), I have not done much in the way of sizing systems.
A ductulator lesson is definetly in order!
Great time seeing you in NYC. You are a real gentlemen! Anthony and myself look forward to seeing you soon.
Darin0 -
Absolutely, Darin!
It is the least I can do for you and your service. Fire off your snail-mail address to me and I will get a nice duct calculator on it's way to you soon. We can do a lesson over the phone although face to face is always far better!
Yes, Friday (into Saturday) was a night to remember. Way too short. Looking forward to seeing you again and to meeting Anthony.
And don't call me sir! I work for a livin'....
Lima calculator
I like the Lima calculator for the return grille sizes on the back. The Lennox ( and more recently , Home Depot ) calculator has the eqivilant length of fittings on the back. Remember , residential supply duct is .10 static within 100 ft to the longest outlet ( linear plus eqiv. length ). Return duct should be based on 600 fpm ( velocity only as compared to equiv. length with in 100 ft ). Low velocity return ducts make for great residential ac and heat pump systems ( and commercial for that matter ). - FREEEEEEEEEAK !!!0
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
