An indirect from Lochinvar worth a look
ALH_4
ALH_4 Member Posts: 1,790
I wonder if they have these water heaters swinging from hangers at the factory like a laundromat? ;-)
Looks good. Why the anode rod in a stainless tank?
    hot_rod Member Posts: 27,386
    316 stainless
    large smooth coil, nice replaceable jacket. Sharp control.
    I like the combo anode rod, lifting ring, and large inspection hole it provides. Easy to see the coils and tank condition.
    It arrived well crated and with a bubble plastic bootie over the tank.
    hot rod
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    How about....
    A shot of the whole tank? Where are the connections for the boiler and domestic water? Chris
  • Paul Rohrs_4
    Paul Rohrs_4 Member Posts: 466
    Looking forward to this.
    Local code officials were only allowing DW heat-exchangers so the new Lochinvar tank was appealing but I wasn't able to use them. Until now, as of today, that code has been repealed. There are a lot of atmospheric boilers around here feeding shell and tube HX for DHW. Did they have to comply? (No).
    This will be a nice addition.
    Regards,
    PR
    all 1\" connections
    with a 3/4 for relief and mid point recirc connection.
    hot rod
