An indirect from Lochinvar worth a look
ALH_4
Member Posts: 1,790
I wonder if they have these water heaters swinging from hangers at the factory like a laundromat? ;-)
Looks good. Why the anode rod in a stainless tank?
316 stainless
large smooth coil, nice replaceable jacket. Sharp control.
I like the combo anode rod, lifting ring, and large inspection hole it provides. Easy to see the coils and tank condition.
It arrived well crated and with a bubble plastic bootie over the tank.
hot rodBob "hot rod" Rohr
Living the hydronic dream0 -
How about....
A shot of the whole tank? Where are the connections for the boiler and domestic water? Chris0 -
Looking forward to this.
Local code officials were only allowing DW heat-exchangers so the new Lochinvar tank was appealing but I wasn't able to use them. Until now, as of today, that code has been repealed. There are a lot of atmospheric boilers around here feeding shell and tube HX for DHW. Did they have to comply? (No).
This will be a nice addition.
Regards,
PR0 -
all 1\" connections
with a 3/4 for relief and mid point recirc connection.
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
