QB 180 parts?
John@Reliable_14
Member Posts: 171
and replace it! You know and I know it's only a matter of time before it fails on a cold night and no parts for three days. It really wasn't a bad burner but could be fussy to set up,that was all that was needed for most oil guys to dislike them. Beckett has the rights to the QB and I've been told they will just spec out a new AFG with a factory welded flange depending on which model boiler. PS just the wholesale price of electrodes is enough to make you replace it, about 5 times the cost of an Beckett kit.
QB 180 parts?
Does anyone know where I can purchase QB 180 parts. they seem to be getting harder and harder to find. Is there an after market manufacturer making replacment parts for this burner?0 -
try your Ferguson company ....
Patriot Supply
Try Patriot Supply 516-249-3100, these guys are the best at finding parts!0 -
Maybe
Maybe tere is a reason it went away. Had it been so good they would have kept it. I haven't had too bad of luck with them but others have. It might be time to replace the burner.
Just a thought,
Leo0 -
QB parts
As said, try patriot supply. I bought a few spare electrodes and other items from them. "Thinking" I may need them someday.0 -
QB-180 parts
I needed an electrode assembly and found Nutley Supply had it in stock. They told me Nutley Supply had purchased most of the QB-180 parts that were around. I'm in New Jersey, perhaps there are Nutley Supplys elsewhere.0 -
I have QB-180 Parts
I manage a plumbing and heating wholesale compain in NY. What do you need? You can also order them through partstoyourdoor.com along with any other part for just about anything HVAC. We use them all the time.0 -
QB-180
Weil-McLain set up 3 master distributor with parts for QB Burners...Call the office located nearest to you...
Philly Area... 856-866-7400
Pittsburg Area...412-788-9345
New York/New Jersey Area...201-797-8550
I know that Nutley Supply In Nutley, NJ was one of the supply houses that was a master parts distributor of QB Parts...
Hope this helps...0
- 167 Indoor-Air Quality
