How do you change the anode on Bradford White Combicor?
Steve Garson_2
Member Posts: 712
Just thinking of preventative maintance. My Combicor is 6 years old. How do I check/replace the anode? There is no documentation on how to do this.
Thanks,
Steve
Thanks,
Steve
Steve from Denver, CO
It is attached to the supply piping going into the heater(cold water side)
Steve...
...I have no hands on experience with Combi-core. However, all other heaters that have anodes have them either with a hex plug on top or combined with the hot outlet. If it is combined, (a combo rod) you will only be able to poke a stiff wire a few inches into the fitting. The anode is suspended below the pipe nipple. Use a pipe wrench to get it out and be sure to put in a combo rod with a longer nipple than came with the heater. It's easier to service later.
Yours, Larry0 -
I'm waiting
For a Brad White pun..0 -
Steve
I think Brad had his Anode rod removed ;-0.
it was causeing him discomfort ;-)
David0 -
Nice, something like that was what I was thinking
Me too....
For GAWD's sake, Dave and Steve! I was fitted at birth with LEFT HAND THREAD!
That hurt!
And why oh why did they have to call it an Anode?
this might help
the anode is on the hot side. here is the link to the service manual. page 24 has your answer.
http://www.bradfordwhite.com/images/shared/pdfs/manuals/44943A.pdf
hope this helps.
Larry0 -
get a grip on yourself Bradford White
If they try to put a cathode where the anode is, run, Bradford, Run.0
