How do you change the anode on Bradford White Combicor?
Just thinking of preventative maintance. My Combicor is 6 years old. How do I check/replace the anode? There is no documentation on how to do this.
Thanks,
Steve
Steve from Denver, CO
  • burninben
    burninben Member Posts: 33
    It is attached to the supply piping going into the heater(cold water side)
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,144
    Steve...
    ...I have no hands on experience with Combi-core. However, all other heaters that have anodes have them either with a hex plug on top or combined with the hot outlet. If it is combined, (a combo rod) you will only be able to poke a stiff wire a few inches into the fitting. The anode is suspended below the pipe nipple. Use a pipe wrench to get it out and be sure to put in a combo rod with a longer nipple than came with the heater. It's easier to service later.
    Yours, Larry
  • S Ebels
    S Ebels Member Posts: 2,322
    I'm waiting
    For a Brad White pun..
  • David Sutton_6
    David Sutton_6 Member Posts: 1,079
    Steve
    I think Brad had his Anode rod removed ;-0.
    it was causeing him discomfort ;-)
    David
  • S Ebels
    Nice, something like that was what I was thinking :)
  • Brad White_159
    Brad White_159 Member Posts: 43
    Me too....
    For GAWD's sake, Dave and Steve! I was fitted at birth with LEFT HAND THREAD!
    That hurt!
    And why oh why did they have to call it an Anode?
  • Larry (from OSHA)
    Larry (from OSHA) Member Posts: 745
    this might help
    the anode is on the hot side. here is the link to the service manual. page 24 has your answer.
    http://www.bradfordwhite.com/images/shared/pdfs/manuals/44943A.pdf
    hope this helps.
    Larry
  • Plumdog_2
    Plumdog_2 Member Posts: 870
    get a grip on yourself Bradford White
    If they try to put a cathode where the anode is, run, Bradford, Run.
