snaking wet returns
I used my super vee to clean out a wet return. It worked great. Is there any reason why this is a bad idea?
  • Sometimes
    The muck and the crap are the only thing holding the pipe together and sealing the leaks. If the pipe is in good shape,then I guess you have a good idea.
  • Mad Dog
    Mad Dog Posts: 2,595
    Right on Billy Boy
    Even when I am snaking a sanitary drain, I always warn people that either acid or a snake will put a hole in rotted pipe. I sound pipe can handle it. On new wet return installations, I like to put 2- 45s rather than 90s, for future snaking ease. I snake out my own (only 3 years old now) wet return every other year and flush...I love seeing those carbuncles come out. Mad Dog
  • yeah but
    if the returns are in that bad of shape they should be replaced anyway. So I guess I will keep doing it. Thanks
  • Hydro Jetting
    I have used my small hydro jetter to clean out returns.
    It is brutal on the hose but cleans and flushes a the same time.
    A super V should not be a problem
    David
    > a bad idea?
