Electric Radiant Heating
hr
Member Posts: 6,106
plenty od simple DIY products available that get installed in the thin set under the tile. I seem Watts Radiant Heatweave or SunTouch brand (at the DIY stores)used quite a bit.
I sent a mat to my sister years ago. She installed the mat and tile and had an electrician wire it properly with a GFI breaker and circuit.
Nothing beats a warm tile floor :) www.wattsradiant.com
may be of help,
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
may be of help,
hot rod
Electric Radiant Heating Suggestion Needed
Hi All, I'm renovating two bathrooms: 5' X 10' and 5' X 8' and would like to install radiant heat under the new floors. Since I live in an apartment building I have to install an electric system. Any suggestions from the pros would be helpful Thanks for your help0 -
I used stepwarmfloor and was pleased with the results.
I like the idea of lower voltage in the floor and the mats are self regulating. With multiple strips you are better protected against one short in a continuos wire scrapping your whole investment. Hopefully your current electrical wiring is such that it makes it easy. Research how you will tie it all in before purchasing anything.
http://www.warmfloor.com/0 -
Easy Heat warrm tiles
Warm tiles is a good product. First you need to see which kit will work for the floor area. Then you need to get an electrician in there to see if You have a circit that is able to handle the extra load.
Depending on floor area, the kits jump from 110 volts to 220 volts.
If you are renting I would okay it with your landlord first.
Gordy0
- 167 Indoor-Air Quality
