Electric Radiant Heating
hr
hr Member Posts: 6,106
plenty od simple DIY products available that get installed in the thin set under the tile. I seem Watts Radiant Heatweave or SunTouch brand (at the DIY stores)used quite a bit.
I sent a mat to my sister years ago. She installed the mat and tile and had an electrician wire it properly with a GFI breaker and circuit.
Nothing beats a warm tile floor :) www.wattsradiant.com
may be of help,
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Electric Radiant Heating Suggestion Needed
    Hi All, I'm renovating two bathrooms: 5' X 10' and 5' X 8' and would like to install radiant heat under the new floors. Since I live in an apartment building I have to install an electric system. Any suggestions from the pros would be helpful Thanks for your help
  • hydronx_3
    hydronx_3 Member Posts: 35
    I used stepwarmfloor and was pleased with the results.
    I like the idea of lower voltage in the floor and the mats are self regulating. With multiple strips you are better protected against one short in a continuos wire scrapping your whole investment. Hopefully your current electrical wiring is such that it makes it easy. Research how you will tie it all in before purchasing anything.
    http://www.warmfloor.com/
  • G.Kaske_2
    G.Kaske_2 Member Posts: 30
    Easy Heat warrm tiles
    Warm tiles is a good product. First you need to see which kit will work for the floor area. Then you need to get an electrician in there to see if You have a circit that is able to handle the extra load.
    Depending on floor area, the kits jump from 110 volts to 220 volts.
    If you are renting I would okay it with your landlord first.
    Gordy
