Tune up / Igniter Adustment ???
Krazy White Rich
Member Posts: 3
the burner is a Beckett model A
furnace tune up
hi everyone,
i want to tune up my oil furnace. it is a Trianco Model # DBC-125. i have no troubles with changing the nozzle tip or filters, but i need to know how to adjust the igniters so it burns effeciently. thanks in advance for your input.
rich0 -
Hello Krazy
Changing things are a brezze but setting it up to run efficent is a hole nother story, you cant set the electrodes to make a burnner run efficent, you can make it light smooth, but tuning it requires instraments, or a combustion analyzer,
What type of burnner do you have ? Boiler is Trianco, burnner is were you got the nozzle out of....
David0 -
off the center of the nozzle --5/16" up, 1/8" forward, 1/8" gap0 -
I agree with David. You can know and make all the adjustments needed but final testing with a combustion test kit is the only way to assure its set-up correctly and more importantly for safe operation.
Your friend in the industry,
Alan R. Mercurio
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
i suggest NOT touching your own oil burner!!! If you do not have test equipment to test combustion, this is not a DIY job. hire a pro!! even changing the nozzle can change burn pattern, combustion, effeciency. THIS LEAD TO A LIFE THREATENING SITUATION. RUN, DON'T WALK TO THE PHONE AND CALL A PRO!!0 -
i cleaned the furnace and adjusted the igniter points on my furnace yesterday and it runs like a champ. thanks guys for your knowledge and your concerns.0 -
What was your combustion analasis results? if you did do a combustion test, you are putting yourself and your family in danger. this is not a HO job.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
