Central MA referral
Ragu_5
Member Posts: 315
Are you folks o.k.?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=428&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Central MASS referral
Can anyone refer me to a steam heat expert in Central Mass?
I have a 1930's house, two-pipe steam system, 5-yr-old Burnham boiler,Barnes & Jones #3 condensater,18 radiators over three floors, with steam traps who-knows-how old. The water hammer is so bad I had to move my daughter out of her bedroom onto the couch.
I read "We Got Steam Heat" and have made whatever adjustments I'm capable of, but I really need someone who can give it the, "yep, that's where your problem is, and this is what needs to be done."
Thanks.
Have you checked
Find a Professional?Retired and loving it.0 -
Depending on where you are
David Sutton and Mike Grinham come to mind, being near Middle Earth . Not to the exclusion of others of course!
Do check around and use Find A Professional too as Dan suggested."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
Sue....
Check out the "Find A Professional" section; the good guys will return your calls, and they will come IF you are serious. Good luck. Jack
Sue (Again)...
What town are you in? I have some good professional friends out on Rte. #2 in Orange and Greenfield. Please advise where you are. Jack
Stem heat
I would be happy to help email radiantwizard@yahoo.com
That's a Barnes & Jones Vapor System
unfortunately I'm in Baltimore or I'd be right there. I'll second David Sutton if you're in his area- he loves Vapor.
Sue
Central Mass is pretty big so it depends where you are. some folks call central the region between 128 and 495 . Others from 495-146. We'd be happy to help with that if your in our coverage area.
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
