Central MA referral
Ragu_5
Member Posts: 315
Are you folks o.k.?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=428&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Central MASS referral
Can anyone refer me to a steam heat expert in Central Mass?
I have a 1930's house, two-pipe steam system, 5-yr-old Burnham boiler,Barnes & Jones #3 condensater,18 radiators over three floors, with steam traps who-knows-how old. The water hammer is so bad I had to move my daughter out of her bedroom onto the couch.
I read "We Got Steam Heat" and have made whatever adjustments I'm capable of, but I really need someone who can give it the, "yep, that's where your problem is, and this is what needs to be done."
Thanks.
Have you checked
Find a Professional?Retired and loving it.0 -
Depending on where you are
David Sutton and Mike Grinham come to mind, being near Middle Earth. Not to the exclusion of others of course!
Do check around and use Find A Professional too as Dan suggested."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
Sue....
Check out the "Find A Professional" section; the good guys will return your calls, and they will come IF you are serious. Good luck. Jack
Sue (Again)...
What town are you in? I have some good professional friends out on Rte. #2 in Orange and Greenfield. Please advise where you are. Jack
Stem heat
I would be happy to help email radiantwizard@yahoo.com
That's a Barnes & Jones Vapor System
unfortunately I'm in Baltimore or I'd be right there. I'll second David Sutton if you're in his area- he loves Vapor.
Sue
Central Mass is pretty big so it depends where you are. some folks call central the region between 128 and 495 . Others from 495-146. We'd be happy to help with that if your in our coverage area.
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 972 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
