what is the correct way to wire a McDonald Miller WP2-U-wrV
Empire_2
Member Posts: 2,340
Now I am HUNGRY!!:-)
Mike T.
Mike T.
wiring McDonald Miller 24V WP2-u-24 FEEDER to a mv low water cto
The low water cutoff has 4 terminls running off the t-stat. 3 people say you wire 1 to neutral, 2 to supply, 3 to xfr, 4 to feeder. Feeder has 3 connection--1 to feeder, 2 to neutral( what does that mean?), 1 is hot. What does hot mean?0 -
What does hot mean?
HOT means you hire someone who knows so you don't cause more damage than you are about to.0 -
Not something you want to guess at..:-)
Mike T.0 -
hmmmmnnnnnnn.......
onna LWC/O ... no less0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
