what is the correct way to wire a McDonald Miller WP2-U-wrV
Empire_2
Member Posts: 2,343
Now I am HUNGRY!!:-)
Mike T.
Mike T.
wiring McDonald Miller 24V WP2-u-24 FEEDER to a mv low water cto
The low water cutoff has 4 terminls running off the t-stat. 3 people say you wire 1 to neutral, 2 to supply, 3 to xfr, 4 to feeder. Feeder has 3 connection--1 to feeder, 2 to neutral( what does that mean?), 1 is hot. What does hot mean?0 -
What does hot mean?
HOT means you hire someone who knows so you don't cause more damage than you are about to.0 -
Not something you want to guess at..:-)
Mike T.0 -
hmmmmnnnnnnn.......
onna LWC/O ... no less0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
