sidewalk heating
Fred Polski
Fred Polski Member Posts: 1
My goal is to heat a sidewalk when it snows or when we get freezing rain. It would not be used all the time,,,only when inclement weather strikes.
I recently poured a concrete sidewalk containing about 350 ft. of 1/2" pvc tubing. The tubing is snaked throughout and is about 2" beneath sidewalk surface. Total sidewalk space is about 400 sq. ft. Could I use an electric 20 gallon hot water heater to heat a glycol solution and then pump it into the walkway?
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    pvc tube???
    for starters...you have got to do a heatloss...unless you do that you are guessing. Did you insulate? you don't know if you even have enough tube to make it work, hopefully so...snowmelt requies a lot of engrgy fast....get the #'s done then you know.kpc
  • Singh_3
    Singh_3 Member Posts: 58
    1/2 pvc tubing or 1/2 pex tubing? big difference.
  • mikea23
    mikea23 Member Posts: 224
    PVC or pex it doesnt much mater 400Sq on one loop of 1/2. With a loop lenght of 350 feet thats about 12" spacing get the jack hammer
  • hr
    hr Member Posts: 6,106
    depends on your expectations
    I plan on at least 100 btus per square foot, or in your case a 40,000 BTU load. You would need a dual element tank with two 6 KW elements to get there. 12KW X 3.41= 40,920.
    The tube spacing is a bit wide and the diameter a bit small for that space, but it would do some melting, slowly :)
    PVC wouldn't be my first choice, but I have actually seen PVC on hot water baseboard systems!
    PVC is not a very glycol friendly product however :( When I did CPVC fire sprink systems we had to use glycerin as the antifreeze. Glycols will go after PVC.
    My neighbor in Utah, the Vanguard rep :) had a 50 gallon 40K input gas fired WH driving some 1/2" PB in about 800 square feet of drive. I'm amazed at how well it actually worked. Slow, but it always got the job done.
    hot rod
  • steven e heat
    steven e heat Member Posts: 2
    please tell me no!!
    please tell me you have several loops of 12 " tube. otherwise your lookin@ bout 100' of head.
