Steel Boiler Manifolds
plastic, copper, brass and stainless steel manifolds, but never steel. I wouldn't want to be the first one to try them either.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Scott HArtman
    Scott HArtman Member Posts: 3
    Steel manifolds
    Hi folks... I'm a wholesaler looking to stock prefabricated steel manifolds. Are there any brands that have exceptional features/benefits/quality and conversely, any that should be avoided? I appreciate help from all of you experts! Thanks...
  • Scott HArtman
    It's really no different...
    > _A
    > 53&Step=30"_To Learn More About This
    > "Find A Professional"_/A_
  • Scott HArtman
    ... than using threaded fittings and steel nipples, which is typical here in NYC. These manifolds are SCH40 steel pipe with outlets that are beveled and welded thereby saving the installer a ton of time. Only in New York!!
  • steve_6
    steve_6 Member Posts: 243
    Earthlee
    check out Earthlee in the virtual trade show section of this website
  • B. Tice
    B. Tice Member Posts: 206
    headers
    I have had good luck with RAVEN products brand.
  • Weezbo
    Weezbo Member Posts: 6,231
    Hello...
    i used some nice steel headers made about 25 30 years ago....these were made out of gun barrel blue steel...havent seen anything like them since however you find the manufacturer i will go back to steel headers.
  • hr
    hr Member Posts: 6,106
    I second earthlee
    www.earthlee.com
    They made me some schedule 40 2" radiant manifolds that were top notch. Excellent welding. Pretty red ones :)
    hot rod
  • ed wallace
    ed wallace Member Posts: 1,612
    manifolds
    please stay away from the chinese made manifolds have had a few leakers and misaligned branches
  • oil-2-4-6-gas
    oil-2-4-6-gas Member Posts: 641
    earth lee i have installed a few with the manifolds always lined up and no leaks yet --there are 2 on my boiler at home also nice product
  • Scott Hartman_2
    Scott Hartman_2 Member Posts: 1
    Gun metal blue
    Just to clarify... the gun metal blue you refer to sounds like it is probably seamless pipe made By Sharon Steel. They dye their seamless pipe a bluish color to differentiate it, which it certainly does. Thanks to you and all the others for your input, I'll investigate Raven and Earthlee.
  • Lee_2
    Lee_2 Member Posts: 48
    Good Evening Gentlemen! I haven't been on "The Wall" in quite some time because I've been just too busy. I want to thank you Dan, for the beautiful write up you gave Speedheaders again in January. It was only this weekend that I read the article and then saw this post. Thank you, you are most kind. Its not easy being female in this line of work, but I feel I have gained the respect of many. Hot Rod, I'm so happy you like the color red. Your header pictures are hanging on my "wall". Steve, thank you and I'm delighted you are happy with the headers. I will agree though, be careful of purchasing headers that aren't fabricated here in the USA. I have had several occasions where customers have mailed me a header thats not mine. They had several leaks and were quite misaligned. I've always replaced the other header, but am quite shocked at the junk people sell.
    As always, I hope all is well with everyone!
