Steel Boiler Manifolds
Alan(CaliforniaRadiant)Forbes
Member Posts: 1,243
plastic, copper, brass and stainless steel manifolds, but never steel. I wouldn't want to be the first one to try them either.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Steel manifolds
Hi folks... I'm a wholesaler looking to stock prefabricated steel manifolds. Are there any brands that have exceptional features/benefits/quality and conversely, any that should be avoided? I appreciate help from all of you experts! Thanks...0 -
It's really no different...
> _A
> 53&Step=30"_To Learn More About This
> "Find A Professional"_/A_
... than using threaded fittings and steel nipples, which is typical here in NYC. These manifolds are SCH40 steel pipe with outlets that are beveled and welded thereby saving the installer a ton of time. Only in New York!!0 -
Earthlee
check out Earthlee in the virtual trade show section of this website0 -
headers
I have had good luck with RAVEN products brand.0 -
Hello...
i used some nice steel headers made about 25 30 years ago....these were made out of gun barrel blue steel...havent seen anything like them since however you find the manufacturer i will go back to steel headers.0 -
I second earthlee
www.earthlee.com
They made me some schedule 40 2" radiant manifolds that were top notch. Excellent welding. Pretty red ones
hot rod
manifolds
please stay away from the chinese made manifolds have had a few leakers and misaligned branches0 -
earth lee i have installed a few with the manifolds always lined up and no leaks yet --there are 2 on my boiler at home also nice product0 -
Gun metal blue
Just to clarify... the gun metal blue you refer to sounds like it is probably seamless pipe made By Sharon Steel. They dye their seamless pipe a bluish color to differentiate it, which it certainly does. Thanks to you and all the others for your input, I'll investigate Raven and Earthlee.0 -
Good Evening Gentlemen! I haven't been on "The Wall" in quite some time because I've been just too busy. I want to thank you Dan, for the beautiful write up you gave Speedheaders again in January. It was only this weekend that I read the article and then saw this post. Thank you, you are most kind. Its not easy being female in this line of work, but I feel I have gained the respect of many. Hot Rod, I'm so happy you like the color red. Your header pictures are hanging on my "wall". Steve, thank you and I'm delighted you are happy with the headers. I will agree though, be careful of purchasing headers that aren't fabricated here in the USA. I have had several occasions where customers have mailed me a header thats not mine. They had several leaks and were quite misaligned. I've always replaced the other header, but am quite shocked at the junk people sell.
As always, I hope all is well with everyone!0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
