Propane Mod Con?
Robert O'Brien
Member Posts: 3,575
oil mod/con. Most all mod/cons can be easily converted to Propane. The use of a mod/con is the only way to consider propane as a viable home heating fuel on Long Island. It's too expensive on a BTU basis otherwise
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=313&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Can modulating
Condensing boilers be used with Propane? Would it make any sense over oil?
Is there any kind of modulating condensing boiler that uses fuel oil?0 -
Peerless Pinnacle
Peerless is offering a condensing oil boiler called the Pinnacle oil.
Tim D.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 988 Plumbing
- 389 Solar
