Propane Mod Con?
Robert O'Brien
Robert O'Brien Member Posts: 3,599
oil mod/con. Most all mod/cons can be easily converted to Propane. The use of a mod/con is the only way to consider propane as a viable home heating fuel on Long Island. It's too expensive on a BTU basis otherwise
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=313&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • realolman
    realolman Member Posts: 513
    Can modulating
    Condensing boilers be used with Propane? Would it make any sense over oil?
    Is there any kind of modulating condensing boiler that uses fuel oil?
  • Tim Doran_4
    Tim Doran_4 Member Posts: 138
    Peerless Pinnacle
    Peerless is offering a condensing oil boiler called the Pinnacle oil.
    Tim D.
