Peerless boiler cracks
Jay_22
Jay_22 Member Posts: 14
I have a peerless wbv-03-110-wpc. The front section that the burner mounts to has a crack at the top corner left side
on the inside of the bend. It goes from about 1/4 into the section all the way thru to about 1 inch below the heat pin between the sections. Is this a weak spot on this boiler.
  • Ken_40
    Ken_40 Member Posts: 1,310
    How about...
    A photo? Just make sure it's no wider than 600 pixels.
    Is it leaking?
  • Big Ed_3
    Big Ed_3 Member Posts: 170
    Front Plate
    Maybe someone over tighten the bolt ,I have not seen a problem out here .
  • Big Ed_3
    Front Plate
    Maybe someone over tighten the bolt or failed to slowly torque in a even pattern ,I have not seen a problem out here .
  • Leo
    Leo Member Posts: 772
    Are you talking
    Are you talking the black front plate that the burner is mounted to? I have seen these crack from excess heat when the boiler isn't maintained. Or are you talking the front boiler section? In my experience Peerless boilers rarely leak.
    Leo
