commercial solar
Larry Weingarten
Larry Weingarten Member Posts: 4,117
... see if you can install a meter on the inlet to the existing water heater. That will give you the info you need to accurately size things.
Yours, Larry
  • Tim_34
    Tim_34 Member Posts: 56
    Commercial Solar Systems
    Can anyone point me to some online conversion tables for sizing solar water heating for a mid size commercial project?
  • Michael Welch
    Michael Welch Member Posts: 43
    Yes you definatly need to measure your water usage for the hot water usage in gallons. take a reading for every day of operation for about 2 weeks this will give you a fairly accurate water ussage to help with determining the required sizing.
