commercial solar
Larry Weingarten
Member Posts: 4,074
... see if you can install a meter on the inlet to the existing water heater. That will give you the info you need to accurately size things.
Yours, Larry
Yours, Larry
Commercial Solar Systems
Can anyone point me to some online conversion tables for sizing solar water heating for a mid size commercial project?0 -
Yes you definatly need to measure your water usage for the hot water usage in gallons. take a reading for every day of operation for about 2 weeks this will give you a fairly accurate water ussage to help with determining the required sizing.
- 87.5K THE MAIN WALL
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
