DO you remember?
Empire_2
Member Posts: 2,340
I remember every time working on this engineering disaster. Although it increased the surface area of the condenser coil it HAD to be separated to properly clean it. In the NE we have cotton seed flying to the point where it looks like snow in late April/May and I could always look forward to customers blank stair when I tell the the price to properly clean it.....
Mike T.
Mike T.
They're back!!!
Not sure what all brands are doing double row coil but the nightmare returns. Anything with a reasonable footprint these days is probably double row. Armstrong's new units are and they look like a real headache to clean!0 -
1 more thing
Do you remember the Carrier condensers with the aluminum bristle design? If you sneezed you would bend the hell out of them.....lol, let alone use a hose on it..:-)
Mike T.0 -
Yea man.
Unfortunately they are still around. And how about the Spine fin coils by GE and Trane? Dandilion magnets.0 -
spine fin
If spine fin coils are so tough to clean why do they still use them in american standard air conditioners?
j.h.0 -
Here's another one...
Older Comfortmaker condenser coils that did not like longer defrost cycles, and would split open. The "bristle" design reminded me of something that should be strung on a Christmas tree!0 -
OMG
I took one of those apart in the customer's yard so i could recycle the aluminum tubing and it unwound as it rolled down the hill. I'll never forget the customer's face and I'm sure he'll never forget mine as I had to carry all that tubing back up the hill. It was after that incident that I wouldn't remove the steel wire cage until I got to the recycle place.
Do y'all know the linear footage of the tubing in an old round carrier? At least AmStd and Trane epoxy the coils together.0 -
Spine fin
Why are they still around? I'll need to ask Trane.0 -
My Guess...
They are cheap to make, lightweight and very rarely leak!0 -
Why then
Why then do they charge so much for their condenser?LOL.
I prefer the double rolls coils.Only because of the lower profile it gives the unit.
Look at all the new high efficent equipment from trane.
The surface area of the coil is so wide and tall that you
have to stand on your head to replace the reversing valve coil or the crankcase heater.
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
