Proper instrument to measure offset pressure of gas valve
I have a Fieldpiece digital dualport manometer but am concerned about the accuracy for sensitive negative pressure gas valve offset adjustments.
I read a post a while back about using a magnehelic gauge with a zero center and very small scale. Can someone point me to where I might purchase one? I believe it was a Dwyer but they make so many insturments, I'm unsure which to get.
Thanks in advance.
  • Ted_9
    Ted_9 Member Posts: 1,718
    Me too
    I know the Dwyers are good. I also saw a small Testo digital one that is good for negative gas valves like the ones you find on the Buderus GB142.
    Massachusetts
  • Ken D.
    Ken D. Member Posts: 836
    Pressure
    Dwyer's Magnahelic in the correct scale is a very accurate and dependable instrument.
  • Steve Ebels_3
    Steve Ebels_3 Member Posts: 1,291
    Testo 506
    I have a couple and find them very accurate. The 506 will do + or - and differential and it's sensitive enough to read W.C." to the third decimal. I've checked it against my Mag and found it to be spot on every time. I know for a fact that Chuck Shaw uses that instrument in his work at HTP.
  • John McArthur_2
    John McArthur_2 Member Posts: 157
    My fieldpiece digital reads to 1/100th of an inch. I'm just unsure of how accurate any of the digitals are.
    Which Dwyer are you guys using? I think the 2300 looks like the one to get, but was unsure if it was safe for combustible gases.
    Thanks guys.
