Proper instrument to measure offset pressure of gas valve
John McArthur_2
Member Posts: 157
I have a Fieldpiece digital dualport manometer but am concerned about the accuracy for sensitive negative pressure gas valve offset adjustments.
I read a post a while back about using a magnehelic gauge with a zero center and very small scale. Can someone point me to where I might purchase one? I believe it was a Dwyer but they make so many insturments, I'm unsure which to get.
Thanks in advance.
Thanks in advance.
Me too
I know the Dwyers are good. I also saw a small Testo digital one that is good for negative gas valves like the ones you find on the Buderus GB142.
Massachusetts
Pressure
Dwyer's Magnahelic in the correct scale is a very accurate and dependable instrument.0 -
Testo 506
I have a couple and find them very accurate. The 506 will do + or - and differential and it's sensitive enough to read W.C." to the third decimal. I've checked it against my Mag and found it to be spot on every time. I know for a fact that Chuck Shaw uses that instrument in his work at HTP.0 -
My fieldpiece digital reads to 1/100th of an inch. I'm just unsure of how accurate any of the digitals are.
Which Dwyer are you guys using? I think the 2300 looks like the one to get, but was unsure if it was safe for combustible gases.
Thanks guys.0
