Spirovent
brucewo1b
Member Posts: 638
the operating table it would be nice if the Dr would stop doing that;-)
Spirovent
Has anyone experenced with a spirovent, that if you makeup the nipple too tight on the bottom inlet it will obstruct the inside spiro mesh and vent will not work.
Yes, several times. I've had to remove the inner core and cut the bottom on an angle and re-install. A real PITA when it happens.0 -
No, but
as the doctor said to the patient, if it hurts when you do that, don't do that.
"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
