Spirovent
brucewo1b
brucewo1b Member Posts: 638
the operating table it would be nice if the Dr would stop doing that;-)
  • Bryan_17
    Bryan_17 Member Posts: 4
    Spirovent
    Has anyone experenced with a spirovent, that if you makeup the nipple too tight on the bottom inlet it will obstruct the inside spiro mesh and vent will not work.
  • John McArthur_2
    John McArthur_2 Member Posts: 157
    Yes, several times. I've had to remove the inner core and cut the bottom on an angle and re-install. A real PITA when it happens.
  • Brad White
    Brad White Member Posts: 2,399
    No, but
    as the doctor said to the patient, if it hurts when you do that, don't do that.
    -Ernie White, my Dad
