Riello F10 problem
william_5
william_5 Member Posts: 62
I have found that some moters that were replaced turned out to be good. the part that was over seen was the strainer in the pump I found out that over the years the only thing that was replace was the oil filter. as with me i just could not get the o-rings to seat right switch to a gasket now i check every pump strainer
hope this helps
william
