Steam Boiler Circuit
Dale
Member Posts: 1,317
The electrical code doesn't require GFI's for dedicated appliance circuits. Also on a boiler with electronic ignition the GFI can cause ignition problems.
Boiler Circuit
Should a boiler circuit be GFI protected since it is hooked up to an appliance containing water?0 -
GFI on boiler
We are not required anywhere here in Maine to install a GFI on the boiler circuit. The heating system is usually very well grounded...the boiler usually sits on the concrete floor or on cement blocks or a pad.
Check you local authority for any possible code requirements.0 -
GFI on boiler
GFI on boiler
- 87K THE MAIN WALL
- 114 Chimneys & Flues
- 106 Geothermal
- 981 Plumbing
- 388 Solar
