Steam Boiler Circuit
Dale
Dale Member Posts: 1,317
The electrical code doesn't require GFI's for dedicated appliance circuits. Also on a boiler with electronic ignition the GFI can cause ignition problems.
  • gehring_3
    gehring_3 Member Posts: 74
    Boiler Circuit
    Should a boiler circuit be GFI protected since it is hooked up to an appliance containing water?
  • Al Letellier_4
    Al Letellier_4 Member Posts: 7
    GFI on boiler
    We are not required anywhere here in Maine to install a GFI on the boiler circuit. The heating system is usually very well grounded...the boiler usually sits on the concrete floor or on cement blocks or a pad.
    Check you local authority for any possible code requirements.
  • Al Letellier_4
    GFI on boiler
  • Al Letellier_4
    GFI on boiler
