Thermostatic Radiator Valves
Ken_40
Ken_40 Member Posts: 1,310
Look inside for a name. Perhaps on the body under the knob/cap?
It looks like neither a Danfoss or Braukmann.
The two almost legible casting letters may be more helpful if your eye can read them for us? The digital is close but an S or C seems to be present. Wrench marks have dulled the remaning to illegibility.
Don't forget the old "compact mirror" trick to see the side buried against the wall.
Any info will help us hep you.
  • Robert Wissing
    Robert Wissing Member Posts: 4
    Does Anyone recognize the attached TRV, and know where I can get them?
  • Al Letellier_9
    Al Letellier_9 Member Posts: 929
    TRV
    use a lot of TRVs but never one like that...may be a OEM part.Do you know who made the rad? That would be a good place to start.
  • Robert Wissing
    Thank you gentlemen. What a great way to get help!!!
  • t.p.tunstall
    t.p.tunstall Member Posts: 18
    thermostatic rad valve
    it's an AGA. is this a baltimore housing job/ late 70's?
    how many do you need?
  • Robert Wissing
    Thermostatic radiator valve
    T.P. Tunstall, thank you. I want 6, but must have 4. Do you know where I can get them?
  • lenny_6
    lenny_6 Member Posts: 2
    heat loss calculations
    can any body tell me , I am looking for a good program to run that i might be able to do a real percise job on hetloss calculations for heat and AC.
    I typicly use a standerd method which through the years of experience I have required works good, but it just seems with the new technology and the customers more educated they want to see some thing more. thankyou Lenny
  • Robert Wissing
    T.P. Tunstall
    Thank's for responding, I need 4 AGA TRV's and would buy six if I could get my hands on them. They are in a residence in Long Beach, New York.
  • Peter Groenewold
    Peter Groenewold Member Posts: 11
    T.P. Tunstall
    You correctly identified an AGA-TRV radiator valve for me a couple of days back. Do you know where I can get them? Also you asked about the location of the work, which is a residence in Long Beach, New York.
