Thermostatic Radiator Valves
Ken_40
Member Posts: 1,310
Look inside for a name. Perhaps on the body under the knob/cap?
It looks like neither a Danfoss or Braukmann.
The two almost legible casting letters may be more helpful if your eye can read them for us? The digital is close but an S or C seems to be present. Wrench marks have dulled the remaning to illegibility.
Don't forget the old "compact mirror" trick to see the side buried against the wall.
Any info will help us hep you.
Does Anyone recognize the attached TRV, and know where I can get them?0 -
TRV
use a lot of TRVs but never one like that...may be a OEM part.Do you know who made the rad? That would be a good place to start.0 -
Thank you gentlemen. What a great way to get help!!!0 -
thermostatic rad valve
it's an AGA. is this a baltimore housing job/ late 70's?
how many do you need?0 -
Thermostatic radiator valve
T.P. Tunstall, thank you. I want 6, but must have 4. Do you know where I can get them?0 -
heat loss calculations
can any body tell me , I am looking for a good program to run that i might be able to do a real percise job on hetloss calculations for heat and AC.
I typicly use a standerd method which through the years of experience I have required works good, but it just seems with the new technology and the customers more educated they want to see some thing more. thankyou Lenny0 -
T.P. Tunstall
Thank's for responding, I need 4 AGA TRV's and would buy six if I could get my hands on them. They are in a residence in Long Beach, New York.0 -
T.P. Tunstall
You correctly identified an AGA-TRV radiator valve for me a couple of days back. Do you know where I can get them? Also you asked about the location of the work, which is a residence in Long Beach, New York.0
- 120 Geothermal
