Soalr Pool Heating
I like that idea. Just started wondering, what about freezing temps. Or do you not get freezing temps in your area? I'm imagining having to blow it out in the fall?
Solar Pool Heating
Can anyone recommend a manufacturer of the low cost solar collectors for pools?
Thanks, Bob Gagnon
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
iwant to give these
a try?
http://shop.solardirect.com/index.php?cPath=69_70_90_104_102
they look interesting.0 -
solar pool panels
Check out Techno-solis0 -
I have two...
Of the Vortex 4x12 panels in use at the neighbor's and I think this is our fourth season with them. I'm very pleased with the product, we put them up and take them down seasonally and just bungi them to the fence surrounding the pool. I rigged them in parallel with 3/4 PVC coming directly off the filter discharge. One was recently damaged by a careless pool guy and the company is giving us a new one under warrantee. They carry a 10 year warrantee. We also have a Triangle Tube/Weil Mclain pool heater that works off the boiler but we've found that once the pool is up to temp the two 4x12 panels will maintain it all summer, very little fuel usage during that time. We condition 30,000 gallons with them. I place them facing east/west straight up against the fence, they catch the morning sun, lose a couple hours around noon and soon as the sun starts down toward the west they'll catch all the afternoon sun as well. Works like a charm.0 -
Roth has
an interesting looking plastic pool panel. Not much of a warranty for some reason???
hrBob "hot rod" Rohr
Afterthought...
A pool cover will reduce heat loss by 300%, you need to cover the pool for best results with the solar panels.0 -
thanks
thats promising new for me.0 -
I used
the concrete pool shirt. Put some piping into the slab and y0u can heat the pool while cooling the concrete.0 -
Pool collectors
Heliocol, great product and warranty, started using them in 1991 and have not come across anything better.0 -
Link?
I found the Heliocol site but I couldn't find any data on the panels themselves. What sizes do they come in?0 -
Heliocol website
Go to the Dealer area and register, they will send you a confirmation and you can access more info0 -
Thanks...
I'll do that!0 -
Just like everything else
You build it to suit your local needs. The ability to drain is always positive.0 -
right...
thanks!0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
