Homeowner Warning !
Matt Undy
Member Posts: 256
I've got some Orangeburg if you want it. I have about 2 5' sections and the rest is scattered in bits throughout piles of dirt in the yard I'm sure you could sift these out and glue them back together with roof cement. It is after all the root proof pipe.
Matt
Matt
Homeowner and DIY Warning!!
I have often seen posted and have verified a very expensive mistake that homeowners and DIYs make.
While radiant suppliers have every right to sell packages here, they may miss lead you to believe that the installation of the in-floor heat loops and related manifolds,insulation etc. are a breeze to install.
Remember that improper placed loops,improper spaced loops,the length of loops and the fine details should be done or coached by experienced installers.
These systems are cast in stone and corrective action due to improper design or installation can cost you not only thousands of dollars in remedial work but the very heat efficiencies you are trying to achieve.
Those of us on "the Wall" who do radiant have no problem with homeowners who want to save money by helping out,but nothing is more frustrating to us than trying to balance or make functional distribution systems that have been installed wrong!
Do your homework as a few hours asking questions may save you tons of money and frustration!
Rich K.
Make Peace Your Passion!0 -
Thanks Rich,
certainly sounds "familiar" to a recent HO posting I had!
Dave0 -
Perhaps you can help then...
The local Farm & Fleet store had this wonderful sale on garden hoses in December. Really good ones for about $5 each.
So if I run those, and leave the ends exposed at the central joist to connect to; and poor glypcrete it should work right.... I figrued that 2 100 ft garden hoses for the living room, 1 for the kitchen, a 50 footer for the bathroom, and because I want warm bedrooms - two 100 footers for each bedroom. I can just loop them so they are even.
It should be easy to connect the hot water and colder return hoses. Can I use garden hose their too?
Do I need more hoses - or will this all work?
Thanks folks,
I'll check back.
piping
Yup! go to the co-op & get yur hoses & slam em' in. Someone will fix-er' up! (if it don't work)0 -
Don't waste your money.
> It should
> too?
> work?
> Thanks folks,
> I'll check back.
In Jest
Nope! This is a "gag" right???
Dave0 -
In Jest...
Thanks Buddy! i just invented a new tool soon to revolutinate the hydronic community *~/:)
Its called the Shreddah.. works like a motorized snake...cut the hose at the floor and feed the Shredda down the hose...then once it is completely spun into dust you throw the wedgie fitting into the slab run the compressor up to like 300 psi and give it a blast...everything shoots out the opening farthest away then one simply pluggs the new pex with a gert magnetic screw ,,the tube has a chinese finger puller on one end of it and the tubing goes through a preheat chamber.. as that is happening it is pulled out into the oversized raceway:)
once it is dialed in either to the correct length for the area or about as close to half way hammer jack the floor out, put a (90) on the tube and run it back to the headder ,shoot some SLU around the new tubing...:) it will be a constant topic of conversation having a couple pieces of pex expanding and contracting on the floor ...and Hey! Problem solved:)0 -
you want radiant?
Try this...0 -
Excellent Mitch!
Is the hose and rad from the same car? I really like well matched equipment.0 -
In Jest?
Gentlemen,
I realize that you are being a little extreme here but we should probaly post a warning like this about once a week. I am sure hundreds of consumers are given advice by dept. clerks at various box stores and internet sites that quite frankly could create a money pit out of their so-called state of the art in-floor systems.
If they have the expertise and ambition I say "Go for .
It".If not bring in a professional!
Rich Kontny
yes
'45 Pontiac0
- 167 Indoor-Air Quality
