Best backflow test kit?
grumpyplumber_2
Member Posts: 19
Barton prime, model 246, not cheap, bellows type, bought and maintained (re-cirtified) from Backflow Consulting, Denver Co. The teacher of the backflow testers course should be able to help with choices and availability in your area.
I need to buy a good quality yet reasonably priced backflow test kit, anyone have a recommendation? Thanks for your help!0 -
backflow
I have a Conbraco 140AC and a Watts TK9A .
I am using the Conbraco right now because I had it recertified this year.
Both are good units but they are not cheap.
I paid $400.00 for each unit 15 years ago...
Dave in NH
29040 -
> I
> Both are good units
> I paid $400.00 for
> Dave in NH
> 2904
Thanks Dave, Is there a reason you recertified the Conbraco and not the Watts?0 -
recertified
The Conbraco needed some repairs as one of the diaphragms inside had ripped .
I did a seach on the internet and found a Company in PA that repaired them. I had them go through it and replace any damaged parts , and recertify it.
The City I live in requires an RPZ to be tested twice a year , and DDC every year.
All testing is done by Private certified testers like myself
Dave in NH
PS: The 15 year old Watts reads the same as the recertified Conbraco , so they don't seem to go out of ajustment.0 -
gauge
Barton prime, model 246, not cheap, bellows type, bought and maintained (re-cirtified) from Backflow Consulting, Denver Co. The teacher of the backflow testers course should be able to help with choices and availability in your area.There was an error rendering this rich post.
