Webster Vapor Vacuum System
Mad Dog_2
Member Posts: 8,537
Yep, Hi temp silicone, rainbow rubber or remove altogether along with clogged old check valves. Mad Dog
I am looking for some detailed information in refrence to an old Webster Vapor Vacuum system. I have a client who has an HB Smith oil fired boiler that was running 6lb pressure and was blowing water out of what looks like a cleanout canister above what looks like a boiler return trap. The canister is feed from the steam header with 11/2"pipe and then drops into the boiler return trap. I have looked into the system in Mr, Holohan book the Lost Art but it does not give much information on the operation and workings of the system.
Does any body have any information for me. I have worked on many vapor vacuum systems and this is the first time I have come across the Webster System. The house is heating fine and I have lowered the pressure on the boiler which has stopped the leak but I want to know about the parts before I take anything apart.
Scott McGuire0 -
vacuum?
Hi Scott,
Does the system have a vacuum pump to create the vacuum? If not, then check out the Library section of this site, upper right. Check under "steam heating", scroll down to "Warren Webster...", go to page 3. See if that diagram matches what you see on-site. I'll be glad to explain.
Best regards, Pat0 -
Webster
Might the canister be the receiver? I assume the dry returns dump into it, and it into the return trap. If water comes out of it, the float is sunk, and the BRT is dead. Drop the pressure. That system is designed to run on 8 ounce of pressure, without the vacuum.
Post some pictures.0 -
Scott McGuire?
From Westchester County NY? If so...
Scott, I'm Mike Fisher's Partner, Al.
I have some experience with these systems. If you need a hand, I can help. Just ran into one today in Rye.
914-804-2234 cell.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
Scott, that's a strainer
I see these a lot on Websters. If the gasket is shot, and you can't find a replacement, some red hi-temp silicone should work.
webster system
Thanks for your help. Located the drawing in the library and it looks some what the same. Will check the jobsite again. The part leaking appears to be a strainer basket feeding the boiler return trap.
Scott0 -
webster system
Thats what I thought. Was looking for confirmation and I thank you for your help0 -
Webster system
> Scott,
> I have some
> Rye.
> 914-804-2234 cell.
> _A
> HREF="http://www.heatinghelp.com/getListed.cfm?id=
> 449&Step=30"_To Learn More About This
> "Find A Professional"_/A_
Webster system
Hey Al,
Was the job you looked at for Hoffman Fuel on 6 George Langleogh Court. I will give you a call in the AM or you can call my cell at 914-490-4339
Thanks,
Scott0 -
webster system
> Post some
> pictures.
webster system
Thanks for the info. Looks lite it is a strainer baket feeding into the boiler retun trap. There is a seperate vent trap that the dry returns enter. Thanks for your input
Scott0 -
Does it look like this?
Yep, hi-temp silicone, rainbow rubber gasket, Mad Dog
Look in the Library
under the topic Steam Heating. Just scroll down for all the info on Webster.
It pays to wander off the Wall.Retired and loving it.0 -
webster system
Thanks for the information. The library was a great help.
Scott0 -
webster system
Not the same style. was able to find info on the system in the library. thanks for your input.
Scott0
- 50 Industry Classes
