Webster Vapor Vacuum System
Mad Dog_2
Mad Dog_2 Member Posts: 8,413
Yep, Hi temp silicone, rainbow rubber or remove altogether along with clogged old check valves. Mad Dog
  • Scott McGuire
    Scott McGuire Member Posts: 21
    I am looking for some detailed information in refrence to an old Webster Vapor Vacuum system. I have a client who has an HB Smith oil fired boiler that was running 6lb pressure and was blowing water out of what looks like a cleanout canister above what looks like a boiler return trap. The canister is feed from the steam header with 11/2"pipe and then drops into the boiler return trap. I have looked into the system in Mr, Holohan book the Lost Art but it does not give much information on the operation and workings of the system.
    Does any body have any information for me. I have worked on many vapor vacuum systems and this is the first time I have come across the Webster System. The house is heating fine and I have lowered the pressure on the boiler which has stopped the leak but I want to know about the parts before I take anything apart.
    Scott McGuire
  • vacuum?
    Hi Scott,
    Does the system have a vacuum pump to create the vacuum? If not, then check out the Library section of this site, upper right. Check under "steam heating", scroll down to "Warren Webster...", go to page 3. See if that diagram matches what you see on-site. I'll be glad to explain.
    Best regards, Pat
  • Fred Harwood_2
    Fred Harwood_2 Member Posts: 196
    Webster
    Might the canister be the receiver? I assume the dry returns dump into it, and it into the return trap. If water comes out of it, the float is sunk, and the BRT is dead. Drop the pressure. That system is designed to run on 8 ounce of pressure, without the vacuum.
    Post some pictures.
  • Al Corelli_2
    Al Corelli_2 Member Posts: 395
    Scott McGuire?
    From Westchester County NY? If so...
    Scott, I'm Mike Fisher's Partner, Al.
    I have some experience with these systems. If you need a hand, I can help. Just ran into one today in Rye.
    914-804-2234 cell.
  • Scott, that's a strainer
    I see these a lot on Websters. If the gasket is shot, and you can't find a replacement, some red hi-temp silicone should work.
  • Scott McGuire
    webster system
    Thanks for your help. Located the drawing in the library and it looks some what the same. Will check the jobsite again. The part leaking appears to be a strainer basket feeding the boiler return trap.
    Scott
  • Scott McGuire
    webster system
    Thats what I thought. Was looking for confirmation and I thank you for your help
  • Scott McGuire
    Webster system
    > Scott,
    > I have some
    > Rye.
    > 914-804-2234 cell.
    > _A
    > HREF="http://www.heatinghelp.com/getListed.cfm?id=
    > 449&Step=30"_To Learn More About This
    > "Find A Professional"_/A_
  • Scott McGuire
    Webster system
    Hey Al,
    Was the job you looked at for Hoffman Fuel on 6 George Langleogh Court. I will give you a call in the AM or you can call my cell at 914-490-4339
    Thanks,
    Scott
  • Scott McGuire
    webster system
    > Post some
    > pictures.
  • Scott McGuire
    webster system
    Thanks for the info. Looks lite it is a strainer baket feeding into the boiler retun trap. There is a seperate vent trap that the dry returns enter. Thanks for your input
    Scott
  • Mad Dog_2
    Does it look like this?
    Yep, hi-temp silicone, rainbow rubber gasket, Mad Dog
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    Look in the Library
    under the topic Steam Heating. Just scroll down for all the info on Webster.
    It pays to wander off the Wall.
    Retired and loving it.
  • Scott McGuire
    webster system
    Thanks for the information. The library was a great help.
    Scott
  • Scott McGuire
    webster system
    Not the same style. was able to find info on the system in the library. thanks for your input.
    Scott
