heating oil
Can you check the undergrown oil tank for leaks?
  • bill_90
    bill_90 Member Posts: 1
    heating oil
    Is it normal to smell diesel after an oil delivery?
    I have no leaks.
    Could this be a ventproblem?
    Seems to dissipate shortly thereafter.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,643
    You might be smelling
    the delivery man. ;-)
    Retired and loving it.
  • lee_7
    lee_7 Member Posts: 457
    It is possible that you have a leak in fill/vent piping. Is the top of your tank appear wet? Is the vent gauge plastic vial loose? any of these things can lead to a smell.
  • chapchap70_2
    chapchap70_2 Member Posts: 147
    What part of the house is the smell the strongest? If this problem is ongoing, go outside and check where the vent pipe ends. Is there a dryer vent or another type of vent nearby? If one of these vents leads to the area where the odor is strongest, you found your problem.
  • Wilner Belizaire
    Wilner Belizaire Member Posts: 3
    Oil leak
    How can you know when your undergrown oil tank is leaking?
    Please give me some examples.
  • brucewo1b
    brucewo1b Member Posts: 638
    It might not be until
    your neighbor finds fuel oil in his sump pump well.
  • Tim P._2
    Tim P._2 Member Posts: 47
    Yes, you can have the tank pressure tested.
    Of course, if the tank is weak you could blow a hole in it.
    If you're that concerned, I would just dig it up. Pretty soon the MAN will make you do it anyway.
    When my brother-in-law bought his house the ins. co gave him 30 days to remove the underground tank or they would terminate coverage.
    Tim
  • Bob_99
    Bob_99 Member Posts: 1
    DO you live in New Jersey...Underground Tanks in the State of New Jersey the State is helping by offering you to replace the underground tank by putting in an above ground Double Wall Tank....Take a look
    Roth and Granby make Double Wall Tanks...
