question for the wall
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,708
The Library keeps growing, thanks to so many generous friends.
Retired and loving it.
  • eddie_6
    eddie_6 Member Posts: 3
    need help
    Guys,
    I'm new to steam heat.
    Is their a problem with curtains touching the radiator?
    Most say that it wont get hot enough for a problem.
  • Vermonter
    Vermonter Member Posts: 57
    If everything's working right then you're fine...
    If you've got spitting air vents you might have a problem with staining... other than that I can't think of a problem.
  • DanHolohan
    This is from the Library
    Fire from Steam Pipes
    It pays to wander off the Wall.
  • Great article Dan
    and I should venture off the "Wall" more than I do! I wonder if those old steam train "firemen" ever caught on fire? LOL.
    Dave
  • If you
    stitch em to the floor, they can't catch on fire(G).
  • zeke
    zeke Member Posts: 223
    You need 450 deg F to burn paper, so at the low boiler pressures you have, it will not get much hotter than 212, the boiling point at atmospheric.Drapes and curtains would need temps much greater than 450 to burn.
