Savings with insulation
Steamhead (in transit)
Member Posts: 6,688
to an old thread, in which I listed heat-loss numbers for the various weatherization stages my house has been thru since it was built:
http://forums.invision.net/Thread.cfm?CFApp=2&Thread_ID=36958&mc=64
By all means do the insulation first. Then, when you do replace that boiler or re-burner it with a lo-hi-lo unit (if a suitable one can be found) you'll find it spends a lot of its running time in low-fire.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I have just discovered that our wood frame facility, which used 5500 gallons of oil this past season has zero insulation in the ceiling/roof. The boiler is 40% oversized and I was planning to replace it, but now that I see no insulation, I figure that should be the first plan of action.
Is this correct logic, as far as payback is concerned?
Steve0 -
Definitely!
What kind of wood scrap do you produce? Did you ever consider a wood boiler. I was at the EconoBurn factory the other day. Very impressive, and Energy Star RAted.
Up to 1 million btu.
Rob0 -
When I said "wood-frame" I simply meant that it is made of 2x4 wood frame:-)0 -
Too many customers
Want the expensive and high dollar heating and cooling systems.
When I look at the house, I look at windows, attic insulation, below floor insulation, etc. It's not only the system, but the envelope!
Case in point: New customer replaced all the windows in his house except one (curved top window above the entrance, about $2500 to replace). Just by replacing all the south facing windows, his power bill went down about $50 per month during the cooling season. He's ready for spending the extra money on high efficiency heating and cooling as soon as he adds insulation to his attic.
You pay for insulation once. After that, it pays you back.0 -
insulation
insulation is the wa to go but you want to really stop the air movement more than anything else so look to Icyneene or a similar spray foam insulation.0 -
I am thinking that icycene is the way to go.0 -
Icenyne is good but if you want more bang for your buck check out CORBOND. Corbond is a closed cell polyurethane spray foam. It is much more dense than icenyne and has an r-value of almost double that of icynene.0 -
I did
Recommend spray foam.
I was in an attic in August under a black roof a few years ago. It was 82 degrees up there. It should have been 120 degrees or better.
