On demand Water Heaters
Does anyone make an on demand water heater like the Rennai that is approved for mobile home use?
Andy Morgan
Riverside Mechanical, LLC
  • Big-D
    Big-D Member Posts: 21
    If you are loking for electric then the answer is yes. check out www.whe.org
  • JackFre
    JackFre Member Posts: 225
    Mobile home approval requires
    that the equipment be "shipped/provided" with the conversion kit. I know that Rinnai's position is that you would be nuts to just provide the kit to a 180k appliance to the homeowner. While they are the right way to go in these domiciles, until the standards change there can be no mh approval.
  • Ken_40
    Ken_40 Member Posts: 1,310
    Andy,
    You may want to consider a straight electric w/h with timer.
    Very effective way to keep energy costs minimal.
